03 600rr problem
Old 12-02-2010, 08:34 AM
SCCBRF2's Avatar
Default 03 600rr problem
I upgraded from an F2 to a 600rr this summer and i went to go riding the other day and it would not crank. I first thought it might be my fuel pump because when i hit the kill switch to the on position, i did not hear the fuel pump running. so i waited til the next day and tried again, but i noticed that the FI light on my guage cluster isnt coming on. does this mean my kill switch may be bad and it could be stuck in the on position? any help would be appreciated
Old 12-02-2010, 08:41 AM
LJ Harp's Avatar
Official CBRF Decal Man
The key was turned all the was.correct? Not being a dick but even I have done that one if it was then go ahead and.take your right controls off and inspect what I do it just start were the source and start taking it apart also ccheck fuses
Old 12-03-2010, 03:41 PM
R Dub's Avatar
October 2011 ROTM
When you say it wouldn't crank do you mean the engine would not even turn over? Or will the engine turn over but not fire?
Old 12-04-2010, 01:06 AM
SCCBRF2's Avatar
yes i had the key turned all the way on. all the lights come on and everything, and if i press the start button the engine turns over just fine. hopefully this weekend i can find some time to check the kill switch and some fuses/relays
Old 12-04-2010, 07:44 AM
johnnyh's Avatar
If it was the kill switch it wouldn't turn over, sounds like you fuel pump or banks angle sencor. Johnnyh
Old 12-25-2010, 03:22 PM
marc0011's Avatar
I had this exact same problem. I also noticed the headlight not working. I probed around and discovered a failure in the ground of the main harness.
There is a little yellow block on the left side of the bike on the main harness. It's a little hard to see because it's taped up with electrical tape. This is were all the grounds for fuse box go to before going to the frame. It burns up and doesn't allow the circuit to be completed.
Mine burned up from corrosion. I took it apart and then soldered the wires to the metal piece that was inside it and then just taped it up. Problem solved.
johnk16
09-18-2016 10:09 AM
volcom440
01-16-2012 12:50 AM
kawc
07-16-2011 10:59 AM
NMJ600rr
06-13-2011 09:58 AM
nitehawk408
04-21-2009 03:01 PM
Quick Reply: 03 600rr problem
