'04 600RR engine problem
Old Jan 15, 2012 | 08:08 PM
volcom440's Avatar
Default '04 600RR engine problem
so my bike is wanting rev all the way up. at first i though it was just at higher speeds but even when i have the clutch pulled in / neutral. so neutral and gears 1-6 my bike wont get past 9.5k. when i get there it acts like its at the rev limiter and kind of sputters. All the RPMs under though the bike performs as normal. im thinking dirty injectors? im not really sure though, any help would be greatly appreciated.
Old Jan 15, 2012 | 10:58 PM
stealthCBR929's Avatar
Official Glory Detailer
do you have any f1 lights in the cluster flashing ? do you have a power comander hooked up? sounds like you could be loosing fuel pressure at high rpm how many miles on the bike ?
Old Jan 15, 2012 | 11:57 PM
volcom440's Avatar
no on the PC, havent noticed the FI light but i'll check through all the gears tomorrow, and if thats the case what could be my solution? i was planning on buying a can of seafoam tomorrow
Old Jan 16, 2012 | 12:50 AM
74demon's Avatar
I dont think its an injector. Sounds electrical. Check all the connectors and wires, especially around the pulse gen, r/r, stator, ecu, tps, and injector harness. Im leaning towards the ignition pick up and charging system stuff. Tps is suspect too. But thats mostly guessing....you know how it is. Happy hunting!
zigurd
Jun 9, 2010 02:17 PM
scott07
Apr 9, 2010 11:45 AM
scott07
Mar 20, 2010 09:57 PM
socnty
May 22, 2008 03:31 PM
SR20DETurbo
Jun 16, 2006 09:54 AM
