Will F4i ignition coils work on the F4?
Thanks for the info iJapanesey!
Mine was still ridable so I hadn't purchased any yet.
The grooves in the coil that the spark plug head go into are warn so I used some aluminum foil to give it a tight fit until I heard back. I just bought a set of 4 on ebay with 17K miles for $30 with shipping.
BTW - for those of you that don't know the aluminum foil trick: Depending on the looseness fold some foil 2/3/4 times for desired thickness and place between the nut and bolt. Then push the bolt into the foil/nut and thread it together. For the sparkplug it just means pushing it together with the foil between the coil plug and the sparkplug head.
