weird rattleing sound
Old Sep 6, 2006 | 03:35 PM
Murph317's Avatar
Default weird rattleing sound
well i layed my bike over a few weeks ago, no major damage just a broken turn signal and scratched fairng on the right side. but ever since there has been this weird rattleing/buzzing sound coming from around the gauge cluster, but it only happens when i get the rpm's over 5K. im not sure if its the gauge cluster or something below it that i just can't see but its starting to drive me nuts. other than the sound my bike runs like normal and havent seen any problem with performance. so im hoping someone may have had this problem before and might be able to help.
Old Sep 6, 2006 | 05:14 PM
2000cbrf4's Avatar
Default RE: weird rattleing sound
I had a loose bolt on my front fender one time that made a similar noise. Couldn't find it for weeks!
Old Sep 6, 2006 | 05:37 PM
ddvs's Avatar
You have a loose bolts/nut combo. Check to make sure everything is tightened down. Otherwise your guage cluster might have a cut in the wiring harness and electricity is jumping from the guage cluster to the frame, causing an electrical current that could in fact electrocute you and you could die. So tighten those bolts!
Old Sep 7, 2006 | 09:18 AM
TrnsferErr's Avatar
hopefully its not your cam chain tensioner. those tend to go bad alot.
Old Sep 7, 2006 | 04:15 PM
ddvs's Avatar
TransferErr, your signature is a link to the picture, can you fix it to where we can see the picture instead of clicking the link to see it? It's annoying... just FYI
Fusikk
Mar 18, 2012 03:04 PM
ariel607
Mar 26, 2011 05:23 PM
Preston777
Jul 6, 2010 06:58 PM
michasiek
Apr 1, 2010 12:22 PM
k4y_d1
Jul 29, 2009 07:47 AM
