water pump gasket.
See Section 6-12 - factory Honda service manual. Removal of water-pump. Check thrust-washer & O-ring (o-ring at back of pump, not inside pump body itself). Could be source. That is unless you have a leak in the pump itself, which would require replacement of the o-ring inside the pump & a new sealing-washer upon re-installation.
This should be a fairly easy project if your handy w/ standard hand tools.
Good luck.
Good luck.
