water pump...
Old Aug 16, 2007 | 03:08 PM
Stunda's Avatar
Default water pump...
now that my stator cover problem is solved...its time to get this one solved also.
my water pump was shattered from the wreck, i took all the bolts out and pulled off the shattered peices, now i just have the part of the pump with the turbine and the part that sticks into the engine case. my question is how the hell do i get that part out? is there something i forgot to remove? is there a trick to getting it out? thanks in advance for your help.
Old Aug 17, 2007 | 06:59 AM
Stunda's Avatar
Default RE: water pump...
bump
Old Aug 17, 2007 | 07:46 AM
madgreek's Avatar
Dude, do you have the manual? If not...here it is:
http://hondatech.info/downloads/Moto/
...the Honda common service manual is on there too.
Old Aug 17, 2007 | 09:18 AM
Nipz's Avatar
There is 4 bold on the water pump. They hold the case on that covers the Turbine.2 of the bold attachthe water pump to the block. The other2 are just tohold the water put together.Remove the 2 bolts that holdthe water pump to the block. then just pull itout.If you need pics let me know. Hope that helps.
~Nipz
TW
Jun 2, 2015 12:12 PM
ucyifly
Mar 31, 2013 09:50 PM
anto1279
May 8, 2009 02:15 PM
faux
Jun 26, 2008 08:51 PM
Heaton830
Jun 2, 2007 01:17 PM
