turn signals
Old Jun 18, 2008 | 05:36 PM
mattmejean's Avatar
Default turn signals
i am about to purchase a 2000 cbr600f4 well there are a couple problems first the turnsignals are broke off. and i can not find a site that says they have any that fit an f4 anyone know where i can get some. second i think the turn signal relay is fried because the battery had a dead short in it so the only way it would run is with a charger hooked up. when i tried the rear signals it made all kinds of noise(the relay) so is it the relay or just because of the charger? if it is the realy where can i get one
Old Jun 19, 2008 | 08:05 AM
mauthman's Avatar
Default RE: turn signals
turn signals are extremely easy to find. if that is the only thing wrong then go for it. Tonnes are listed on ebay so check there. I got flushmounts for 20$ and haven't had any problems so far. There will also be relays on there too.. best place to look
Old Jun 19, 2008 | 09:09 AM
PlayfulGod's Avatar
+1 on ebay. Mine were only $20 and havent had issue one with them. They are just turn signals tho, I have the dodads to make running lights too but I like em like they are.
Old Jun 19, 2008 | 09:18 AM
N8 Dawg's Avatar
Most flush mounts are universal, mine I just had to cut the fairing where the two holes were and just make it one hole. you can buy the ones for your model that require no cutting but I figured I was never going back to the HUGE stock turn signals. as far as the relay making a bunch of noise...could be since there are no front turn signals the wires might be touching and causing a short...I would look at it when you install new turn signals and you should be able to figure it out.
and playfulgod whats dodads? are you talking about a diode?
Old Jun 19, 2008 | 09:22 AM
PlayfulGod's Avatar
ORIGINAL: N8 Dawg
yea, that be them lol. Knew what they were but was having a brain fart
Lowridese
May 1, 2010 01:12 AM
MrBlaze
Aug 17, 2009 02:07 AM
playb0i
Jan 2, 2009 04:55 PM
Terry954rr
Jul 25, 2008 08:32 PM
Neutron
Sep 28, 2006 02:47 PM
