turn signals
turn signals
i am about to purchase a 2000 cbr600f4 well there are a couple problems first the turnsignals are broke off. and i can not find a site that says they have any that fit an f4 anyone know where i can get some. second i think the turn signal relay is fried because the battery had a dead short in it so the only way it would run is with a charger hooked up. when i tried the rear signals it made all kinds of noise(the relay) so is it the relay or just because of the charger? if it is the realy where can i get one
RE: turn signals
Most flush mounts are universal, mine I just had to cut the fairing where the two holes were and just make it one hole. you can buy the ones for your model that require no cutting but I figured I was never going back to the HUGE stock turn signals. as far as the relay making a bunch of noise...could be since there are no front turn signals the wires might be touching and causing a short...I would look at it when you install new turn signals and you should be able to figure it out.
and playfulgod whats dodads? are you talking about a diode?
RE: turn signals
ORIGINAL: N8 Dawg
Lowridese
05-01-2010 01:12 AM
