Turn Signals
I have a serious problem with my turn signals ....on back of the bike I have those installed http://www.911moto.com/store/images/...al/ledtip2.jpg , and on front i have the normal honda signals shorter version....my problem is my signals work on the right side of the bike and on the left they are dead , I disasamble the front right signal and connect only the left and the left side work. If I connect all the 4 signals only one side will work either left or right side of the bike.
On front the signals are wired on right (green and light blue)
left (green and orange)
I've checked all the fuses and they are ok.
OK.. got the wiring diagram here...
I had to edit this because I thought you said front signals.. so I went from that...
rear signals are left hand:
orange
green
right hand:
light blue
green
Green is definately the ground. Did you resolder or crimp the stock connectors back on? Can you put the one 'good' side on the other side to see if it is the wiring or the light itself?
Are the signals on the front 3 wire or 2 wire? if 2 wire, what did you do with the running light wire? LED or Incandescent?
Adam
orange
green
right hand:
light blue
green
Adam
The short story of the signals is that...i have an accident and all my front fairing was gone.
Before the accident I have Led Turn signals on back and front of the bike...now I have put normal signals on upper front of the bike.
I did not resolder the stock connectors the former owner did that but i take off all the duct tape and recheck them. I take ground wire from the headlight because it splits in three one goes to the headlight and two remain ground for the turn signals
The signals in the front are 2 wire and are conected on right hand :green and light blue
on left hand :green and orange
Only one wire left alone and taped and is brown, and i believe that's the running light.
Back signals are led, front are bulb normal signals.
Ps. I put them on the "good side" on the other side and they work just fine....
If I connect only three signals they work...meaning 2 on back and one either on left or right side, then both sides of the bike work.
Lowridese
May 1, 2010 01:12 AM
