Torque Wrench Recommendations/Info
Hi all, Im after a Torque Wrench for doing Rear Brakes and Rotor. Ive seen this LINK
It does 7-112 Nm which should cover Rotor bolts and Calipers bolts and Rear Axel Nut and is a 3/8 head.
Does this look suitable or should i save up abit and spend more on a Higher end Wrench?
Cheers
Cheers
Take a look at this one, middle of the road but should suffice
https://www.ebay.co.uk/itm/VonHaus-T...MAAOSwb-1cUYbr
Thx for the info Cabaret, looks good but looking at the torque value range i need for the brake job, the lowest is 23nm for the the caliper pin and highest
is 93nm for Rear axel nut. and the Magnusen one covers that range but the the VonHaus one doesnt go low enough. cheers.
