Ticking issue
Old Apr 23, 2007 | 02:14 PM
threepee's Avatar
Default Ticking issue
Has anyone had a ticking noise when at idle. It's seems as is it happens after the bike it warmed up for a awhile. I went a delearship and they siad it a common issue but to not worry about it cause it doesn't affect the bike just makes a little noise. has anyone experienced this before and had it fixed or know how to fix it.
Old Apr 23, 2007 | 07:00 PM
cwmc29's Avatar
Default RE: Ticking issue
Yeah I have noticed the same thing. I think some people have said it is the cam chain might be loose. But I have no idea.
Old Apr 23, 2007 | 07:11 PM
fireplug's Avatar
same problem here. My friend who bought a f4 when they first came out said he remembers the same noise. From everything that I have read it sounds like that is just a noise the bikes makes.
Old Apr 23, 2007 | 10:13 PM
threepee's Avatar
I talked to a honda mechanic and he siad i need a valve adjustment.
Old Apr 23, 2007 | 11:58 PM
LoCbRf4's Avatar
ITS THE CAM CHAIN TENSIONER...VERY COMMON PROBLEM ALSO KNOWN AS THE CCT, THERE ARE A COUPLE OF THREADS ABOUT THIS. HOPE THEY HELP.
Old Apr 24, 2007 | 01:37 PM
threepee's Avatar
if it is the cam chain tensioner, "which i have no idea where it is or what it is". would i still be hearing the noise from right under the tank? is this a big job to fix and can you do it yourself....
Old Apr 24, 2007 | 06:24 PM
LoCbRf4's Avatar
YOU WILL ACTUALLY THINK THE NOISE IS COMING FROM UNDER THE TANK, ETC..ALMOST EVERYWHERE YOU WILL BE ABLE TO HEAR IT. TAKE A SCOPE, LIKE THE ONES A DOCTOR CHECKS YOUR HEARTBEAT WITH OR A MECHANICAL ONE, LISTEN TOTHE RIGHT SIDE ABOVE THE CLUTCH COVER AND AROUND THAT AREA . YOU WILL REALLY HEAR IT GOOD WITH THAT. https://cbrforum.com/m_194038/tm.htm THIS IS LINK TO THE CCT INSTALL, YOU CAN DO IT YOURSELF IF YOU HAVE SOME MECHANICAL SKILLS, BUT YOU WILL WANT TO REALLY UINDERSTAND EVGERYTHING YOU ARE DOING. YOU CAN DAMAGE PARTS IF DONE INCORRECTLY! ITS MORE OR LESS A PAIN TO DO. HOPE THAT HELPS.
Old Apr 24, 2007 | 08:02 PM
krash's Avatar
CCT rattles are VERY LOUD, JUST LIKE YOUR TYPING.
it is possible, but doubtful at idle. Usually here a CCT higher up than idle, 5k and up. sounds like bb's in a can.
what you are hearing could be what is commonly reffered to as the Honda tick. mine does it at idle as well. everyone tells me, not to worry about it
they all do that. I am not saying dont worry about, but apparently...............dont worry about it.
Old Apr 24, 2007 | 08:51 PM
LoCbRf4's Avatar
THANK YOU MR.OBVIOUS, I MIGHT OF NOT KNOWN I WAS TYPING IN ALL CAPS BUT JUST LIKE KRASH SAID ALOT OF F4 HAVE THIS PROBLEM. BUT YOU DO DID TO WORRY ABOUT IT IF GETS REALLY BAD. BECUASE PARTS WILL GET DAMAGED.
[hr]
Old Apr 26, 2007 | 01:55 PM
ajlong's Avatar
Krash is right, if it is the CCTL, the noise would be about 5K rpm and up. Ifthe ticking is at idle, I'dlet your mechanic have a listen and go with what he suggests.
