Throttle stuck open when turned right
Old May 8, 2013 | 09:53 PM
sdecoteau's Avatar
Registered Users
Default Throttle stuck open when turned right
Well I recently had the trouble of fixing my headlight by going into the throttle housing and soldering the wire back on, one problem down. Problem is putting everything back together my throttle now sticks open when the handlebars are turned all the way to the right. I've slacked off everything basically as far as it will go, greased everything and don't appear to have any binds as I havent touched anything besides disconnecting the throttle cable in the housing.
Is there something I am missing, or do I just spend more hours looking and fiddling, or give up and take it into the shop to get gouged by shop fees?
Old May 10, 2013 | 04:59 PM
yz125's Avatar
I think I had this problem on another bike. I think the problem was cable routing / cable kink / not enough throttle cable lube.
Old May 10, 2013 | 05:04 PM
hawkwind's Avatar
If it worked OK before, then it's something you've changed. Start with that.
Old May 10, 2013 | 05:11 PM
CorruptFile's Avatar
June 2013 ROTM
99% sure it's the throttle cable not being routed correctly.
cpolaris502
Jun 29, 2012 10:45 PM
FlashNYC
Sep 22, 2011 07:24 PM
mpw3ed
Mar 14, 2011 08:59 AM
oneshotuno
Aug 31, 2008 07:13 PM
