throttle range?????
If I had to take a guess I would say you have a pilot jet clogged up. Take the carb apart and the pilot jet is the smaller one at the bottom of the carb right beside the main jet which is probably a 135 or something close. I had same problem on my FZR and it turned out to be the gas. The ethanol had clogged up the carbs. WATCH OUT FOR THE ETHANOL GASOLINE. I have several bikes and that crap is causing havic on the carborated bikes.
