tachometer stoped working and miles rested to zero?
Old Apr 13, 2011 | 07:51 PM
jkilby18's Avatar
Default tachometer stoped working and miles rested to zero?
does any one know why it would randomly stop working? everything else works ill find out tom if the speedo works or not.... maybe a blown dash?
Old Apr 14, 2011 | 01:04 AM
Bladed101's Avatar
Check your Fuse's.
Old Apr 14, 2011 | 06:01 AM
jkilby18's Avatar
i checked them first.. everthign else works on the cluster but the tach.... it worked the night before but the next morning it wasnt working
Old Apr 14, 2011 | 09:14 PM
jkilby18's Avatar
so i went for a ride today, the speedo doesnt work, the tachometer doesnt and the temp guage doesnt work either..... but all the signals, high beat , oil and other indicators work just fine..im dumbfounded...does any one have any ideas?
Old Apr 14, 2011 | 10:27 PM
Bladed101's Avatar
Not a clue on this one. Your best bet may be to take it to the shop.
Old Apr 14, 2011 | 11:27 PM
mooseboy's Avatar
gotta be a cut wire somewhere i would thinkk
Old Apr 15, 2011 | 03:43 PM
dhurley1's Avatar
sure none of the fuses are blown? sounds alot like a short somewhere
Old Apr 15, 2011 | 08:15 PM
turk in gm's Avatar
check the connectors in the wiring hub on the front of the bike.
if this doesnt fix it, clean the hell out of it and sell it as low miles.
Old Apr 16, 2011 | 07:31 AM
jkilby18's Avatar
it has to be a bad cluster.. i tested all the wires at the front harness and they all volted right up, i found a new cluster for 40 bucks so hoping that should fix my problems...if not down to the shop it goes =/ aaha
Old May 6, 2012 | 08:01 PM
ncruz4386's Avatar
Registered Users
I know it's been a while but I'm having a similar issue. What was wrong? also did you have any problems with the bike not going very fast when the gauges weren't working? Like bogging down ?
amipinoy
Sep 10, 2020 09:15 AM
fratzke7
Sep 10, 2020 09:13 AM
Matt40567
F2 Tech
Jun 7, 2011 05:21 PM
sunny-d
Mar 18, 2009 10:16 PM
islandinatoilet
Jun 23, 2008 01:08 PM
