Swingarm spools
Old Sep 2, 2011 | 04:07 AM
CJardine's Avatar
Track junkie & modaholic
Default Swingarm spools
For those that have installed them; did you drill and tap or weld the attachment points.
I ran my fingers along the swing arms to make sure I wasn't crazy when I couldn't find them.
Old Sep 3, 2011 | 05:48 PM
GrimeyLimey's Avatar
Hi,
Mine has mounts welded on.
DON'T drill and tap, you'll just damage / weaken the swingarm and I doubt there would be enough meat on the walls of the box section to get a decent thread
What do you need bobbins for? Just buy a paddock stand with cups
Old Sep 4, 2011 | 02:16 AM
geno420hy's Avatar
Default Spools
I found this guy in SF bay area Craigslist.I bought his custom made spools that require no drilling,check out this link.They look & fit perfect! Geno
Axle sliders CBR 600RR & 1000RR
Old Sep 4, 2011 | 03:34 AM
They are crash protectors, the spools on that bike are smaller and mounted under the arm.
You make a good point though, there are adjuster blocks with paddock stand mounts, not seen any available for a bike this old though. They look a bit like this
http://www.gillestooling.com/cms/sho...=109&view=info
Old Sep 4, 2011 | 11:02 AM
gotcbr's Avatar
I toyed w/ the idea at one point of welding up the mounts but opted not to do it b/c it isn't absolutely necessary. I've been using a Pit-Bull rear stand for years w/o any problems. I use the Pit-Bull rear stand that has a reversible standard pads & spooled. Since I have more than one bike, I can just flip it over to use as the particular bike requires. Its extremely study & lifts by positioning under the swingarm at the axle. I've used it at the track many times for chain adjustments, tire changes, etc.
Good luck on whatever you decide to do.
Old Sep 4, 2011 | 04:09 PM
CJardine's Avatar
I opted for a stand with the pads and it works good, but I was wondering what others did about the spools, because I have seen them on a few F4s. the Stands not a pitbull but Itll do for my budget.
cbninjar02
Mar 12, 2008 01:48 PM
fireplug
Sep 4, 2006 07:35 PM
MOF4
Dec 15, 2005 09:23 AM
sikanimator
Dec 2, 2005 11:55 AM
APCh8r
Nov 28, 2005 07:46 PM
