Sparkplugs
Old Jan 15, 2005 | 01:15 PM
mindz's Avatar
Default Sparkplugs
What kind of aftermarket plugs you guys running? Do they make those Densol Iridim(sp?) for are bikes?Is that a good plug or just overpriced and overmarketed?
Old Feb 27, 2005 | 03:25 PM
motorbuff929rr's Avatar
Default RE: Sparkplugs
ngk has an iridium style plug also, which is what i put in my f4 before i got rid of it, you can cross refernce the denso to the ngk and vice versa, i cant be quite sure but it seemed to help, it uses like 25% less power to create the same amount of spark as regular plugs, which i would think should give u a better response,
Old Mar 11, 2005 | 12:01 AM
F4Brian's Avatar
I replaced my plugs with the stock ones from Honda. The next time I replace them which is coming up soon is I will pull the fuel tank this time what a pain. I can't remember which plugs Honda sells OEM.
Old Mar 11, 2005 | 01:28 PM
1000RR's Avatar
ORIGINAL: motorbuff929rr
No. Just less draw on the stator. Marketing...
Replace with OEM honda. Check your manual.
Old Mar 12, 2005 | 04:45 AM
mach9's Avatar
I just replaced the plugs in my '99 F4 with OEM honda plugs....this of course was after hitting up every auto parts store in town looking for the NGK and Denso equivalent plugs. NO ONE carries the part numbers you need, your better off just sticking to the OEM plugs in my opinion. You can find them easily online, but why would you want to bother? If your determined though I have both the Denso and NGK part numbers if you want them.
Old May 27, 2008 | 01:46 AM
bgrider's Avatar
ngk stock
Old May 27, 2008 | 06:03 AM
Daveaf's Avatar
Mach9 what are the NKG plug #'s?
Old May 27, 2008 | 08:34 PM
motogiya's Avatar
i used NGK iridium spark plugs.. works great. pain in the *** to get to.
Old May 27, 2008 | 09:56 PM
cwmc29's Avatar
I used NGK Iridium. I find the bike works great with them.
mbison83
Jul 24, 2009 03:49 PM
nekidfrog
Mar 19, 2009 04:26 AM
harleygal
Oct 24, 2008 09:25 PM
CBR1000RRMARINE
May 14, 2007 02:26 AM
mindz
May 5, 2005 06:33 PM
