sparkplugs
Old Dec 9, 2007 | 01:20 PM
harleygal's Avatar
Default sparkplugs
Trying to change the spark plugs in my 600 CBR - books says to remove radiator - is that necessary??
Old Dec 9, 2007 | 03:34 PM
rodantking's Avatar
Default RE: sparkplugs
No. lift tank and remove airbox and your there. To lift tank. remove front bolts and rear. Remove garmet in the rear and replace the rear bolts about 3 or 4 turns. lift the front. I use my breaker bar to keep the tank up.
Old Oct 24, 2008 | 09:24 AM
F4LL3N's Avatar
Can anyone tell me what size socket is needed for F4i 01 spark plugs? And is it just a case of loosening them, popping em out and screwing the new ones in (genuine honda spark plugs that is) ?
Old Oct 24, 2008 | 09:54 AM
glacier_white_F4i's Avatar
5/8 socket. sounds like you get the jist of it. i use ngk plugs but there's nothing wrong with honda genuine.
Old Oct 24, 2008 | 12:16 PM
DBEAU's Avatar
Anyone ever heard of those new E3 plugs? They advertise increased fuel economy and power...
Old Oct 24, 2008 | 12:35 PM
Stephens's Avatar
Stay with NGK. Can a spark plug really improve gas mileage or improve power? Some say yes and others say no. Good gas mileage is based on how you drive, hard and fast or slow and careful.
Old Oct 24, 2008 | 01:00 PM
there is a new plug out that does increase power...to the tune of about 5-10whp on a 350z. dyno'd. then again they're about25 bucks a pop.
i think it has some kind of capacitor in the plug.
Old Oct 24, 2008 | 01:16 PM
travsstuff's Avatar
ORIGINAL: glacier_white_F4i
enlighten us, do they make them for bikes???........I am sure we can all use an extra couple HP by just changing plugs.....
I understand how this may help acar, but sportbike plugs are already pretty high heat output. Just stick with NGK iridium plugs and you will be good.....
Old Oct 24, 2008 | 02:33 PM
WXT's Avatar
WXT
If you have a small enough socket wrench, you do not need to remove anything at all. There is sufficient space to change spark plugs from the side.
i'm not sure if they make them for bikes. www.pulstarpulseplugs.com
on an s2000 they made 7whp and 11ft/lbs...that's pretty damn impressive for a spark plug
