Show your F4!
K so its been a while and some work has been done/ongoing....
Done so far
New rear light cluster
Indicators removed
Front flush indicators
Probolt gold Aluminium screen kit
Probolt gold titanium bar ends, brake resevoir cap and yolk nut
Probolt Gold engine kit
Probolt filler cap kit
Mirrors removed
Centre stand removed
Flo Yello Tyre Strips
Double Bubble Iridium Screen
Double HH Sintered Pads
Probolt gold cable and brake adjusters
Probolt aluminium gold oil filler cap & Gold Ali dustcaps
Dunlop Qualifier RR rubber - Now Dunlop Roadsmart II's
K&N Air/Oil Filters
New Chain/Sprockets added - Soon to be removed for new ones!
Exhaust - Removed
Standard decals - Gone
Goodridge braided flo yello brakes lines
Scottoiler
New Heelplates
Still to be done
Yellow Fairings are getting sprayed black (waiting to pick up!)
Undertray, Hugger & possibly front mud guard (undecided) to be sprayed yellow (waiting to pick up)
Fit rear wheel with new rubber
Fix front master cylinder
Fix throttle cables
clean/polish forks
Clean or paint swing arm (undecided til new colour scheme)
Split seat conversion as per GotCBR (nightmare finding parts in UK/IOM)
Lights to HID (any help/links would most appreciated)
Air intake LED's (again any help most appreciated)
F4I speedo conversion
Carbon fibre vinyl on intake/front fairing plastics
Replace rear shock
Possible yellow neons to downlight of some sort (Any links for UK supplier?)
Weld rear gold probolt bobbins to swingarm
any other crazy ideas.....
When i got her
An oldie
A while back
Tasty Nuts...
Recent Work
Current State
Feedback, thoughts suggestions welcome...
Done so far
Indicators removed
Mirrors removed
K&N Air/Oil Filters
Exhaust - Removed
Scottoiler
New Heelplates
Still to be done
Fix throttle cables
clean/polish forks
Replace rear shock
When i got her
An oldie
A while back
Tasty Nuts...
Recent Work
Current State
Nothing! see 3rd picture down, thats how i'm running her, no silencer!
Loudasf***! just the way i like it!
More pictures coming soon after the re-spray, sprockets, chain and rear wheel fitted.
Would you run your car with no exhaust? just cut it all out at the headers and call it good? If you want noise get an aftermarket exhaust without a silencer. The engine wasn't designed to not have an exhaust.
Id run my car with no exhaust, I have before at the headers. First let's talk about preference, if you want to sacrifice a little tq/hp for a loud exhaust, by all means that's the OPs choice. A muffler is just that, it muffles, hence why he called it a silencer. You can clearly see the header is still there, just no "silencer" Now, keep in mind there's also a certain amount of back pressure that's applied from the mufflers that the motor needs for maximum power output.
The downpipes are still there i just removed the silencer (job in is the description) and i've consulted an engineer who's been building bikes for the TT for over 30 years, he said its absolutely fine to run with no silencer as the connecting pipes at the downpipes reduce any issues with any back pressure, any other bike such as injected models would have an issue but since its a 99 carb'd engine with stock downpipes, its all good!
an i dont have a car mate, dont need one...
@GotCBR - tell me bout it man! its hard work getting companies in the UK to make anything smaller!! it will be getting switched out at some point tho!
in other news my new chain n sprocket has arrived!
