Shifting into 2nd gear.
Old Aug 29, 2012 | 04:36 PM
EViR's Avatar
Question Shifting into 2nd gear.
Hey guys, i was just curious if their was anything i could do to fix this problem.
While driving sometimes when i shift from first to second it hits neutral and i just rev it up, of course i quickly kick it up to seconds but its getting a little old.
Should i try adjusting the clutch or is this something that im doing wrong.
Old Aug 30, 2012 | 06:14 AM
EViR's Avatar
bump
Old Aug 31, 2012 | 06:21 AM
Pugheaven's Avatar
Mmmmm, I find that you need a bigger change up from 1st to 2nd anyway than all the other gears to make sure you miss neutral, however maybe that's a subconscious thing.
However, if it were me, maybe check the clutch cables etc and make sure all is lubed up properly. Do you have any problems in ANY other gear? if not, I think it's just one of them and you just need to be a little heavier on the change.
Old Aug 31, 2012 | 06:56 AM
IslandBoy's Avatar
If you don't solve your problem with practice you can reset your shift lever to a lower position to help with shifts.
TommyHammond
Apr 18, 2012 10:33 PM
edz4life
Apr 19, 2011 07:58 PM
ben_cbr
Jul 28, 2009 09:30 PM
jester61
May 15, 2007 12:16 PM
Fatboy
Jan 26, 2007 01:10 PM
