Removing California Emissions?
Old Mar 11, 2007 | 06:17 AM
bigassbunny's Avatar
Default Removing California Emissions?
Hello! I have purchased a '99 CBR 600 and I'm looking to remove the California emissions stuff. Specifically, the "charcoal can" is leaking gas, so I want to get rid of it. Anyone know of any sites or manuals that go through how to do this? Also, are there any specific CA emissions items I should be sure to remove in order to get more power, or is it more trouble than it's worth?
Thanks!
Old Mar 19, 2007 | 05:43 PM
mach9's Avatar
Default RE: Removing California Emissions?
If I recall the California edition bikes have different cams as well, so it very well may be more trouble than its worth.
Old Mar 30, 2007 | 01:53 PM
baja74vw's Avatar
ORIGINAL: bigassbunny
Thanks!
Hey Bigassbunny,
I was looking for the same thing years ago for a F2 and LOTS of experimenting later, I have some answers.
I put them on my webpage here:
www.magneticdrainplug.com/Tech_Links/CBR_Desmog_1.html
Once you know what the difference is, it is really not that hard.
Hope this helps!
Tim
Old Dec 17, 2023 | 11:29 AM
Tarzan369's Avatar
Default Emissions delete
Do u have the write up of removing the emissions on the 99 cbr600f4
Old Dec 17, 2023 | 12:27 PM
dannoxyz's Avatar
None of CA emissions stuff lowers power, so removing won’t gain you any. Main benefit is weight-savings. I measured something around 0,15-0,20 sec/lap @ Laguna Seca after I removed: PAIR valves, EVAP canister, purge valve and all related hoses. Saved about 5-lbs. Got way better improvements in lap times of 0,25-0,30 sec/lap going with lithium battery which removed 9-lbs off bike.
rwijnhov
Oct 6, 2020 12:58 PM
aireq
Jun 27, 2010 12:33 AM
bigassbunny
Mar 11, 2007 04:51 PM
suream
Jun 5, 2006 08:09 PM
nswhite
Jul 22, 2005 01:56 PM
