Rear Brake rotor HOT
Old Jan 10, 2006 | 04:14 PM
sbeana22's Avatar
Default Rear Brake rotor HOT
I recently replaced the rear tire and brake pads on my bike. I thought at first I put it back together wrong but I checked it twice and it is correct. But after only 10 mins of riding my rear rotor gets extremely hot. What is wrong? I am think that the caliper might be bad and not releasing but I am new to all of this so I am hoping to get some more experienced opinions.
Old Jan 10, 2006 | 06:43 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Rear Brake rotor HOT
Did the piston come all the way out? Did ya clean it really good before pushing the piston back in? I doubt the caliper is trashed -- maybe a seal. Most likely you just need to clean all the brake dust off and push the piston in farther. Then pump it back up and it will seat its self.
Old Jan 11, 2006 | 11:00 PM
sbeana22's Avatar
I took your words of advice and cleaned everything up real good and it seems to be fine. Thanks again.
Old Jan 12, 2006 | 02:33 PM
ChrisMcD's Avatar
Retired Admin
An alternative solution to this problem is carrying a bottle of poland spring water and when they get hot just stopping and soaking them to cool them off!! That should eliminate the hot problem?
[:@]Sorry just in one of those moods today........[8D]
Old Jan 19, 2006 | 03:37 AM
spldrong's Avatar
well I would start by doing what these guys say and cleaning it.. make sure your wheel spacers are not reverced.. I dout that though.. then change your rear brake fluid..and that should probebly do the trick..
And then there is always the obvious... maybe just maybe .. take your foot off the rear brake petal
good luck
kevdiggity
Sep 12, 2008 10:18 PM
mcvaaahhh
Sep 9, 2008 01:24 PM
Thorax
Mar 10, 2008 03:39 PM
letz827
Aug 21, 2006 07:37 PM
