Quick question about F4 dashboard(clocks)
Hi, i have a question about F4 clocks. I am in doubts. When you switch ignition on is rpm gauge must go maximum then go minimum? Or it happening when you switch ignition on and then switching RUN on ?
Or it is not happening at all?
The problem is that i am suspecting my cdi is burned, i have no spark and rpm gauge is not moving. ive saw that F4i rpm is moving always when you hit ignition on.
please reply, dear F4 owners.
RE: Quick question about F4 dashboard(clocks)
as far as i know when you turn the key to ON the gauges are going to move from minimum to max than back down ,may be your battery is dead ? UPDATE do you have f4 or f4i cuz f4 have manual gauges and f4i have digital gauges (manual meaning arrows pointing how fast your going ) and on the f4 the gauges never move .
viva_brasil
06-09-2008 04:38 AM
