"Dashboard" Lights
Old Dec 23, 2007 | 12:29 AM
weinzimer's Avatar
Default "Dashboard" Lights
My turn signals, side stand, and high beam lights on my "dashboard" of my 96 CBR 1000 do not light when I use the turn signals, have the side down while in neutral with engine running, or have the high beams working. My turn signals work properly, high beam works properly, and side stand cuts engine off properly, but the lights on the dashboard do not light as they should. It should be noted my neutral and oil light work as they should. I have checked all fuses. Has anyone run into this problem before? Anyone have a circuit diagram for this model they can send me? weinzimer@yahoo.com
Old Dec 27, 2007 | 04:15 AM
Shadow's Avatar
Default RE: "Dashboard" Lights
Sounds like an earthing problem
Old Dec 27, 2007 | 03:54 PM
BLUE1000F's Avatar
Like Shadow1 said - earthing problem -
I would check the nearest connector coming to the dashboard for earth/ground connection and oxide/corrosion....then the next connector in line and so on.While you are going thrue the connectors...spray some "electronic spray" for better contact.
Sorry don't have a cicuit diagram for that model(year) but i believe someone on this forum has.
Good luck and let us know !
Old Dec 30, 2007 | 06:21 AM
Shadow's Avatar
I have diagram - send me an e-mail address and I'll scan it and e-mail to you.
Old Dec 30, 2007 | 10:37 AM
CosmoBob's Avatar
There is a circuit diagram in section 18 of the Service manual, which, for the time being, can be found here. NOT ANYMORE.
Old Dec 30, 2007 | 04:49 PM
Weinzimer hasn't been back on the board since he posted the question. I'm not too sure he's interested in any of the answers. Awful nice of you to post the manual CosmoBob.
Old Jan 9, 2008 | 04:04 AM
weinzimer's Avatar
Guys-Thanks for the replies and sorry for the delay, but I have been riding during the holidaysacross the Arabian Penninsula. The weather is perfect this time of year 75F andvery little rain.CosmoBob-Goodcolor. I missed your URL, but I have contacted Shadow1 for a drawing. Bryan Weinzimer
Old Jan 9, 2008 | 05:23 AM
CosmoBob's Avatar
ORIGINAL: weinzimer
Thanks to Trips, Honda Common Service Manual & CBR1000F Manual can be found Here
Alex Kerr
CBR1000F Wanted / Swap
Nov 21, 2012 11:21 AM
BiggMatt600f4
Jul 10, 2011 02:08 PM
Thefly
Aug 30, 2009 10:42 AM
woo545
Mar 24, 2008 12:52 PM
Bklynjoker
May 16, 2007 08:40 PM
