quick carb jet question
Old Jul 13, 2009 | 11:23 PM
foxracing12's Avatar
Default quick carb jet question
I ran a search to find this but couldn't find anything conclusive. I recently bought a yoshimura rs-3 on here, and I like the pipe but I am thinking about rejetting the carbs so they are better tuned for the pipe. Anyone here have good experiences/recommendations about which kit I should use for a pipe tune? thank you for your input.
Old Jul 14, 2009 | 03:41 AM
catatonic's Avatar
I used the Dynojet stage 1 kit with my Two Brothers slip on and K&N drop in, works great.
Old Jul 14, 2009 | 12:27 PM
brveagle's Avatar
Why are you rejetting? Chances are your A/F ratio is right where it needs to be.
Either install a wideband or take it to a dyno to confirm, before you start messing with jets.
Old Jul 14, 2009 | 01:26 PM
johnnyx's Avatar
My Stage 2 runs rich at low speeds, but it provided a noticable boost once I really have the ram air kicking in. I'd imagine the Stage 1 would have been a better way to go. That's on my F3 though, so take it with a grain of salt.
Old Jul 14, 2009 | 04:55 PM
after installing the exhaust i feel a little hesitation when i first go WOT. Generally I've heard that when you install aftermarket exhausts a rejet is necessary. Plus, if I can milk a few HP out of a rejet.. I'll sacrifice a few MPG's any day! Based on what I've heard from this thread I am probably going to pick up a dynojet stage 1 kit. Thank you guys.
Old Jul 16, 2009 | 04:00 PM
johnnyx's Avatar
If you're going to do it, then you absolutely must have the K&N filter, or you're not going to be sucking enough air through, and you'll bog the engine down. May want to mod the airbox while you're in there.
Old Jul 17, 2009 | 02:09 AM
catatonic's Avatar
You realize you can just jet your carbs to accept a new slip on right? You don't NEED to put a K&N drop in in there.
Old Jul 17, 2009 | 04:49 PM
I know. The amount of airflow between a stock filter and a K&N is not enough to really screw with the a/f ratio. I am an auto mechanic and don't deal with carbs often but I know all about auto mods! What is this airbox mod that was mentioned?? I can't seem to find any info on this mod.
Bordo
The Hurricane Saloon
Dec 17, 2012 10:14 AM
5p00f3r
F2 Tech
Jan 28, 2012 11:58 PM
antatious
F2 Tech
Aug 18, 2011 11:36 PM
viva_brasil
Jun 9, 2008 04:38 AM
Relff2
Sep 15, 2006 09:32 PM
