PILOT JET setting
Old Feb 25, 2013 | 03:01 AM
Dean0's Avatar
Default PILOT JET setting
Slight confusion and queery
There is an initial pilot screw setting of around 2 1/4 to 3 1/8 turns out depending on the model you have.
Then they run you through the idle drop procedure in order to finally set the pilot screw.
And then they tell you the final pilot screw position should be 3/4 or 1 turn out depending on the model you have.
Why do we not just set the pilot screw to 3/4 or 1 turn out and leave it there if that is where it is going to end up ?
Am I missing something ?
EDIT - yes I am missing something - the ability to read correctly !!!!!!!!!!
Set the idle to 1200rpm
From the initial setting you adjust the pilot screw on No4 carb to achieve the highest tickover possible
Then repeat on the other three carbs.
Reset the idle to 1200rpm
Turn in carb 4 pilot screw till engine drops 50rpm - THEN unscrew by 3/4 turn.
Repeat on the other three carbs.
NOW - which right angle screwdriver can anyone recommend to get at the pilot screw on the 600F carbs ?
MZ5
May 18, 2011 06:26 AM
RunwayOneSix
Mar 7, 2010 11:24 PM
woo545
May 13, 2008 08:52 AM
kennys223
Feb 7, 2008 11:45 PM
04CBR600RR
Mar 20, 2006 10:04 PM
