Is this part for a f4?
Old Feb 22, 2009 | 11:37 PM
platnumbob's Avatar
Default Is this part for a f4?
I am just wondering if this ebay fuel pump is actually for an f4....looks a bit different than the one I need to replace on my 2000 f4. Can anyone confirm that this is correct?
http://cgi.ebay.com/ebaymotors/HONDA...ayphotohosting
Old Feb 23, 2009 | 09:24 PM
platnumbob's Avatar
No takers?... I have been told it works just fine I just want to make sure its going to work on my bike.
Old Feb 23, 2009 | 09:47 PM
jonld's Avatar
if its actually off a 99 f4 then it will work on yours. It looks similar to the ones Ive had on mine, but its been a little while since I worked on it for me to say its exact. Whats wrong with the one you have. When mine quit working, i disassembled it and cleaned the contacts inside and its worked ever since.
Old Feb 23, 2009 | 10:18 PM
PlayfulGod's Avatar
looks to be one for a f4, the f4i's is mount in the tank.
Old Feb 24, 2009 | 12:03 AM
platnumbob's Avatar
The problem with mine is that it is leaking gas...from the "breather" tube that runs from the middle of the pump. Oddly enough I do not see a conection for that hose on this one off of ebay but it may be on the side that is not showing. From what I am told I either have a stuck float/ carb problem or a faulty fuel pump. I figured I would try a new fuel pump first.
Old Feb 24, 2009 | 06:27 PM
CB750's Avatar
How much pressure do those put out?
Old Feb 24, 2009 | 08:06 PM
Aweasel's Avatar
very small...only a few psi. it's also in pulses instead of a constant stream. I read somewhere a while back pressure is like 3-4psi
CorruptFile
May 27, 2013 05:05 PM
iceman423
Jan 1, 2010 12:34 PM
BrokeJoke
Sep 20, 2009 08:08 PM
