Oil/Plugs
Old Aug 2, 2006 | 09:42 PM
angryscientist's Avatar
Default Oil/Plugs
well ive been having a hell of a time deciding/determining which oil/filter to use and what plugs to use.
The plan was Mobile 1 Full synthetic oil, and a wix filter. Orielly couldnt find a filter specifically for the 99 600f4, but they had the same filter listed for alot of bikes but id didnt want to risk it.
as far as plugs go, what do you guys recommend?
Any other recommendations for stuff i can pick up locally? (oreilly/autozone/napa all nearby and a honda motorcycle dealership)
Old Aug 2, 2006 | 10:13 PM
Tahoe SC's Avatar
Default RE: Oil/Plugs
for plugs
NGK CR9EH-9 (std)
NGK CR9EHIX-9 (iridium)
oil filter...
http://motorcycleinfo.calsci.com/FilterXRef.html
i am currently using mobile 1 M1-110...
just make sure it's a quality filter and the bypass pressure is the same as bikes.
t
Old Aug 3, 2006 | 12:07 AM
hill1513's Avatar
The Fram Motorcycle filter is the PH6017a. The automotive equivalent is the PH6607 or the much better TG6607. I recommend the Mobil 1 mentioned above. Currently I have the KN on mine (HP1004 I think).
Old Aug 3, 2006 | 07:52 PM
so just regular old mobile 1 full synthetic 10-40? Or is there a motorcycle specific mobile 1?
Old Aug 3, 2006 | 10:59 PM
hill1513's Avatar
Mobil only makes the car oil. However, many have used it without problems. I use a motorcycle specific full synthetic that, as they say, "provides superior wet clutch protection." Could be BS, but gives me piece of mind.
Old Aug 4, 2006 | 12:36 AM
ok, where are you getting the motorcycle oil?
Old Aug 4, 2006 | 01:38 AM
hill1513's Avatar
You can get it straight from Honda. I opted for the cheaper route and got the Valvoline motorcycle oil from a retail auto parts store. Motul also makes a very good motorcycle oil.
Old May 10, 2008 | 01:16 PM
bgrider's Avatar
ORIGINAL: Tahoe SC
for plugs
NGK CR9EH-9 (std)
oil filter...
t
i am buying plugs now and i really do not know which of these two are better.
I understand that the iridium are the preium ones but can i use them on my standard f4
i am open as far as ideas for air filter too
Old May 10, 2008 | 06:26 PM
MikeInCtown's Avatar
if you can wait a little bit check out the Purolator ones at Amazon. The Purolator website has the motorcycle specific ones listed and they don't have the pressure drop associated with the Pure One filters. Anyway, you can easily get the filters for $5 or less in a two pack and if you order $25 worth of crap they give you free shipping. (I order a handful for both the truck and m/c at the same time)
VeryMotley
Dec 2, 2009 03:15 PM
BigNate354
Jul 30, 2008 03:41 PM
iroc_254u
Apr 9, 2008 05:37 AM
95HondaCBRF3
Jun 11, 2007 01:58 PM
bigboycbr
Nov 10, 2005 06:32 PM
