Oil change
Old May 13, 2013 | 04:55 PM
nutz's Avatar
Default Oil change
Doing a oil change this weekend and was just wondering how many liters I need as this is my first go, already got the filter and cup wrench. Just gotta get the oil now.
Old May 13, 2013 | 05:06 PM
Fobwareagle's Avatar
It's 3.5 quarts with a filter my man
Old May 13, 2013 | 05:11 PM
nutz's Avatar
Thank you!
Old May 14, 2013 | 09:08 AM
M1ke's Avatar
Is changing the oil on our bikes as simple as it is on a car? Pull the drain plug, pull the filter, close the drain, install the filter, use a funnel to fill it up. Then carefully lean the bike up off the kickstand to check that the oil level is correct.
That it?
Old May 14, 2013 | 02:08 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
That it?
I'd start it and let it run for 20-30 seconds to let the oil circulate through the filter. Then shut it off and check the level after 10 minutes so the oil can settle down.
Don't forget to put a film of fresh oil on the filter gasket before you screw it on. I don't think they do this at the factory, which is why my first oil change on any new vehicle is always a bear to get that filter off.
Old May 22, 2013 | 06:56 AM
nutz's Avatar
All done, thanks for everyone's help!
Old May 22, 2013 | 07:43 AM
nutz's Avatar
That it?
Yeah, its thats simple. Enjoyed doing it!
stealthCBR929
May 24, 2012 03:15 PM
89HurricaneF1
May 7, 2012 09:52 PM
michealparks
Feb 10, 2010 12:16 PM
fiveoh
Jul 8, 2008 10:43 AM
otisdr
Aug 7, 2006 06:51 AM
