No spark solution
Old Jun 16, 2022 | 12:52 PM
F4cbr600's Avatar
Default No spark solution
So i’ve seen a lot of people on here getting a no spark issue even after replacing a bunch of parts, i have found in most cases including mine it’s the zener diode on the pink wire going out to the ignition. And for people that have the after market ignition like i do there are wire that need to be moved on the ignition itself. I figured I’d share as Ive been dealing with the no spark for about a month and had to search multiple forums to piece together everything.
The zener diode is a 3.9V 0.5w
I used a 3.9v 1w
I placed the diode by the ecu itself instead of at the ignition for easier access if something happens down the line.
I disconnected the black wire from the ignition and moved the green wire to the open port
If anyone needs more pictures or information feel free to ask
I hope this help as a strait answer like this one would have helped me ALOT
In the photo with the diode there’s a pink wire and a red wire attached to it. They are both the pink wire, I needed to extend it.
Old Jun 16, 2022 | 01:40 PM
@F4cbr600 Welcome to the forum. Thanks for sharing this information and you're right that's a common issue. Is there additional information about the specific Zener Diode you used, like part number, or source where you acquired it?
Old Jun 16, 2022 | 02:17 PM
F4cbr600's Avatar
The part number for the diode is NTE5007A
You can get them from electrical supply stores or amazon/ebay for dirt cheap
Old Aug 18, 2024 | 09:19 PM
Chris71's Avatar
Default My no spark cbr
I used a 3.9v 1w
Hey is there a way I can get your number so I can ask u a few questions I'm having the same issue or can u text me or call 9729214746 Chris it would be greatly appreciated thanks
Old Dec 25, 2024 | 02:03 AM
Michaelkzn's Avatar
Default I need help
I used a 3.9v 1w
Mine doesn't have the pink wire on the ignition but has the diode option I have multiple pink wires on the ecu and one under the headlight iin the harnass I do not have spark and have ordered a new regulator but tested the one I Have and seems to be working
Old Dec 26, 2024 | 08:30 AM
Do you have the HISS system on your bike? If so that has a different immobilizer set up.
You could also have an aftermarket ignition that is not set up correctly.
Is the bike new to you?
Stu Osborne
May 24, 2018 04:01 PM
F4iguy518
Mar 3, 2018 03:19 AM
Mat
Jun 27, 2016 06:28 PM
whiteknight
Apr 18, 2007 06:43 PM
