New chain and sprocket
Old Apr 8, 2024 | 09:31 AM
AidanPanvalkar's Avatar
Default New chain and sprocket
Hi all
recently became the owner of a CBR600F4 after passing my test back in March.
I took on my first chain maintenance this weekend as I could see the chain was quite dirty and definitely needed tensioning. As I disassembled the front sprocket cover I was shocked by the mass of grease built up - it was literally caked in there and took some time to clean.
Q1 - is this normal or is it a sign of a previously poorly maintained chain.
Q2 - the chain is showing some surface rust, is this ok for continued use?
Q3 - I’ve seen this sprocket and chain set, would anyone be able to comment on the quality and price or provide recommendation?
https://huntersmotorcycles.co.uk/product/honda-cbr600-fx-fy-jt-gold-x-ring-heavy-duty-chain-and-jt-black-sprocket-kit-set-4263
New biker so apologies if these are newbie type questions.
Old Apr 8, 2024 | 09:44 AM
Chain maintenance is always fun.
Q1 - Normal esp if wax chain lube is used
Q2 - Some surface rust is fine, main issue is does the chain run smoothly with no kinking and make sure the sprocket teeth are in good order with no hooking.
Q3 - Looks fine to me.
No worries about the questions, keep them coming and take it easy out there.
If you assume everyone is out to get you you won't go far wrong.
Plenty of slow speed maneuvers and braking in car parks to hone your skills
Old Apr 8, 2024 | 09:49 AM
Connella08's Avatar
on the contrary. it usually indicates that the chain was frequently lubricated. as the bike was ridden, the lubrication gets slung off the chain into the front sprocket area causing a build up of thick sludge.
its probably ok, but it really depends on how much there is and how long its been there for. if you intend on replacing the set, then I would say run it while you wait for the new stuff to arrive.
https://huntersmotorcycles.co.uk/pro...t-kit-set-4263
JT makes quality stuff and the X-ring chain is definitely good to have.
Old Apr 10, 2024 | 02:27 PM
dannoxyz's Avatar
Yeah, X-ring chains have less drag than previous-generation O-ring chains.
I oil my chain every other tank. Clean it once per month.
Measure then and verify not too worn.
Mario072
F4i - Wanted
Mar 11, 2013 07:50 AM
fitter537
Jan 20, 2011 11:32 AM
Jay_J
Aug 15, 2010 10:09 PM
Jinkin02
Mar 23, 2010 07:29 PM
terror
Dec 11, 2007 05:50 PM
