Need Help not starting
Old Mar 13, 2011 | 12:16 PM
moosestng's Avatar
Registered Users
Exclamation Need Help not starting
Ok over the winter I have taken on painting and cleaning my bike as a project to keep me saine. Well its all finished and I put everything back together and the damn thing will not start. I belive its the fuel pump and I know this is a common problem. but I have some questions .
1. I pulled the fuel line going into the carb and when I turn the key I dont get any fuel coming out. Only when I turn the key off do I get a small pulse of fuel coming out .
2. where is this fuel relay I keep hearing about I just want to change it !!!
3. why does this blow so much and why do I keep wiping tears from my eyes !!!!! Lol
any help will be very welcomed
Old Mar 13, 2011 | 12:43 PM
moosestng's Avatar
Registered Users
ok I just pulled the fuel pump and hooked it up direct to the battery and it runs so im assuming its the relay !!!!
Old Mar 13, 2011 | 02:41 PM
moosestng's Avatar
Registered Users
Ok so here is where I'm at in this saga !!! I pulled the fuel pump and hooked it up directly to the battery and it pulses just fine . I pulled the fuel cut off relay and I'm assuming this is what goes bad . My new question is when I hook up the fuel pump without any hoses to the system and turn on the key it only pulses once and this occurs only when I turn the key off . Any thoughts before I spend the 70 dollars on a new relay
Old Mar 15, 2011 | 09:21 PM
fiddy_nutz's Avatar
Yeah run the fuel gravity feed from the tank to get it running and rule out carb issues. I run mine gravity feed all the time now.
Old Mar 16, 2011 | 08:47 PM
moosestng's Avatar
Registered Users
How are you running the lines that you can gravity feed it ? Also don't you experience fuel starvation under heavy load ???
Old Mar 17, 2011 | 05:28 PM
Blindside's Avatar
May sound like a dumb question but you turned the fuel valve back on after putting it back together right?
Old Mar 20, 2011 | 09:44 AM
moosestng's Avatar
Registered Users
Hahaha I did turn it on !!!! I picked up the new relay and the puppy fired right up !!! All is right in the world now
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
