my resto-mod
Old Apr 4, 2009 | 01:17 AM
limpy88's Avatar
Default my resto-mod
all right to tell the truth half of the things on my sig are not on the bike but sitting in my house and in the garge next to to the bike. the bike is almost completely apart
what was on when i bought it
targa tinted windscreen, D&D black slip on, cheap aftermarket turn signals(wired wrong), chopped rear mud flap, fake carbonfiber gas cap sticker(removed), aftermarket mirrors(involuntarly removed)
what i have already installed
CRG roll-a-click foldable levers, OPP racing carbon fiber front fender and rear hugger/chain guard, vortex frame sliders, APE cct, NRC leftside cover, hot bodies front signals, yellow bar ends(lost one at the begining of feb this year), throttle rocker(must have for long trips), ebc pads all arond, new clutch cable, K&N filter
stuff being done now
what is be rebuildet, changed, inspected, cleaned, or adjusted
front calipers, front master cylinder, rear caliper, rear master cylinder, new pin sliders for all calipers, new bolts for front calipers, choke cable, new side gauge plastic. (all the seals and hardware from honda for that was well over $300, only place to get it) new shorter front fender/brake line holders bolts. replacing the folowing with stainless hardware(salt&rain has killed these) phillip screws in wind screen and fairings, air duct cover screws, mirror bolt screws, rear chain gaurd bolts. already did the 32k valve clearance check. still need to check the steering head bearings, rear suspension bearings, front fork seals, wheel bearings, float bowl height
what is now being installed
Converti bars, custom made front stainless lines(cheaper and longer than the goodridge kit which didn't fit stock anyway), goodridge rear stainless lines. factory pro jet kit, factory pro 4deg timing advance, factory pro shift star kit, vortex front and rear spockets 15 front 46 rear. rk 520gsw silver chain, race tech 1.0 kg front springs. laminar clear touring lip, pro grip yellow gel grips. vortex rear spindle with stainless bolts.
the only that i order that isn't here is a "speedo healer"
what i will be buying monday
a new rear spring rated for my weight.
here are some progress picks from today i removed the rear shock cleaned it up and took off the factory spring
i also thought while i was on this spending spree i bought
a respro bandit scarf its a carbon filter riding mask for ridin in the city
aerostitch rainboot covers
aerostitch titanium tire arms
aerostitch titanium slide on 27mm socket
aerostitch tubless tire repair kit
aerostitch triple digit glove raincovers
motion pro bead buddy
K.I.S.S. money clip knife
6 pack of miracle tape
motion pro mini chain press
motion pro mini chain breaker
a new shield for my n-102
pacsafe tank bag
pacsafe helemt bag
pacsafe gear bag
alpinestars gp plus gloves
alpinestars smx-r boots
draggin jeans
i still want to do the dual seat conversion and a competion werk under tail but haven't found one in a decent price yet.
chimp1
Rides
28
Feb 12, 2014 07:31 PM
Darenb68
Nov 9, 2013 02:43 PM
Darenb68
Aug 5, 2013 12:52 PM
thisismyacct
Sep 8, 2008 12:00 PM
