master cylinder and calipers: cleaned and still not working right??wtf
Old Dec 19, 2011 | 11:01 AM
cBrentb's Avatar
Default master cylinder and calipers: cleaned and still not working right??wtf
I mean the all the seals look ok, not broken or torn at all so i lubed and put them back in. only thing that looks bad is the boot/cover at the master cylinder where it touches the brake lever. can the seals still be bad even if they look good? my brakes are still draging bad
Old Dec 19, 2011 | 02:11 PM
gotcbr's Avatar
Did you follow the procedure to the letter in the factory service manual?
Did you flush/fill/bleed the system?
How are your brake lines?...original?...replacements?
Old Dec 19, 2011 | 04:58 PM
cBrentb's Avatar
Default yeah, I did bleed the right way. I ordered a rebuild kit for the calipers and master
I polished the caliper pistons to a mirror shine along with the cleaning job I did for the calipers and master cylinder...still dragging. i hope the rebuild kits will fix the problem. if not I will replace the pistons and brake lines. I should have the rebuild kit put on by thurs or fri. can the caliper seals still be bad even if they look ok? I know they are the original ones. the bike has 30,000 miles on it.
Old Dec 19, 2011 | 05:56 PM
MadHattr059's Avatar
Did you clean and add grease into the boots of the hanger pins?
If the brakes are dragging, usually that's the problem not the pistons of the
calipers.
Ern
Old Dec 19, 2011 | 06:57 PM
cBrentb's Avatar
yeah, polished, clean and greased the pins too. thanks tho. ive been reading up on the threads on here, on how you guys been fixing this problem ...lotta good stuff. thanks. cant wait til those rebuild kits come in. some peeps been telling me those rebuild kits will make it feel like new brakes.. hope so.
Old Dec 20, 2011 | 04:32 PM
Project96's Avatar
Have you made sure the pivot pin is not sticking in the lever? Just a thought. The master cylinder rebuild kits make a difference if thats the problem. When I see sticking brakes, it usually ends up being sticking pistons in the caliper/s or the slide pins in the calipers.
Old Dec 21, 2011 | 09:47 AM
cBrentb's Avatar
i just picked up the parts from honda shop, gonna rebuild master cylinder and caliper piston seals today. check my brake line at the same time too. hope this does the trick i'll report back later this afternoon and let ya'll know if that was it. thanks
Old Dec 21, 2011 | 12:12 PM
gotcbr's Avatar
Hope your rebuild goes well.
Old Dec 21, 2011 | 03:19 PM
cBrentb's Avatar
Default calipers and master cyl. rebuild done...still dragging the front brakes
****! this effin bike is going to the shop
Old Dec 21, 2011 | 03:38 PM
74demon's Avatar
rubber brake hoses can collapse internally. are you still running stock brake lines?
also, i had dragging brakes when a shop mixed up my front wheel spacers during a tire change. did you have the front wheel off?
