manual cct help
Old May 10, 2011 | 01:23 PM
ohio nitro's Avatar
Default manual cct help
how tight should i go with the adjustment for the cam chain with the manual cct
Old May 10, 2011 | 03:00 PM
9-5=4rr's Avatar
I think the manual called for 1/4-3/8 inch of deflection on the cam chain if you take off the valve cover to check it out ...
I've always set em by ear ... you gotta be pretty careful tho ... with your engine running at idle, you just adjust em out till you hear the cam chain getting noisy, then adjust it back in slowly till the sound goes away ... too far and it'll start to make a "whiney'' noise ... that's it ...
squidhead
Apr 22, 2012 06:26 AM
dracowing14
Dec 27, 2011 07:24 AM
Trips
Jul 15, 2009 10:56 AM
trash99
Mar 16, 2006 04:22 AM
aclarkgto
Feb 15, 2006 02:41 AM
