Low beam keeps burning out on F4
Old 04-03-2009, 06:54 AM
wagsjr's Avatar
Default Low beam keeps burning out on F4
So I put one in last july. Prolly has 20 hours run time if that and burned out again. Anyone have any suggestions.
I do have LED flush signals and undertail with LED. I am doing the 01 - 03 conversion this weekend so I have a new led rear light with resistores built in.Not sure if old led has them or not
Old 04-03-2009, 12:32 PM
cwmc29's Avatar
I had the same problem and it turned out to be the voltage rectifier / regulater. I just checked out Bike Bandit and they will bend you over for the tune of $160 for this. I got mine off of eBay for half the price, switched her up and no problem-o.
Old 04-03-2009, 02:12 PM
wagsjr's Avatar
U have problems with anything else going bad?
Old 04-03-2009, 09:18 PM
NetBSD's Avatar
have you checked the connections on both the light and the harness. a loose wire will cause this.
Old 04-04-2009, 12:26 AM
wagsjr's Avatar
No. My wife has to. LOL. I cant get my hand in there. It is actually the high beam that went out. And I noticed the blue light on the dash stopped comin on when I switch to the high beam too. That should come on even if its burnt out.
Old 04-04-2009, 01:20 PM
BGm6er88's Avatar
check the battery voltage with the bike running.. when my voltage regulator went out, i had 20v and it blew my headlight.
Old 04-04-2009, 10:25 PM
wagsjr's Avatar
would not having load resistors on the front turn signals matter?
and why only the low beam?
Old 04-06-2009, 12:06 PM
cwmc29's Avatar
No that is the only thing I had go on the bike. I went through a couple of headlights before posting on here for help. Changed the regulator out and I have had no problems since. She runs like a champ.
Old 04-06-2009, 05:54 PM
wagsjr's Avatar
Bulb wasnt connected properly. Simple fix. The whole thing would have blown I think if it was regulator. Thanks though. If it continues I will look into that
__Z__
11-15-2010 03:52 PM
Turbulenz
10-31-2010 06:52 PM
buknoy
07-01-2009 06:18 PM
justasquid
10-07-2008 03:21 AM
ddaren
11-26-2006 07:02 PM
Quick Reply: Low beam keeps burning out on F4
