Improving mid range power?
Howdy,
I was just wondering if there is anything out there to improve the mid range a bit? My bike is running fine but I just came across these 'Velocity Stack' things and it said to improve the mid range on motorcycles (or at least smooth out the curve a bit).
So is there anything out there? I'm not into hp gains or racing etc. Just wondering.
(Ps: Half de-baffled carbon Micron slipon, running stock everything else.)
I agree with changing gearing for more overall thrust, but in terms of increasing actual engine power output any noticeable degree on a non-turbo engine, you'd need to change cams, and prepare to lose power somewhere in exchange for gaining it elsewhere.
Mid range,
Full Arrow system, this gets rid of a lot of the issues, but the only way to fully remove the mid range dip is to get rid of the ignition retardation and fueliing limitation that the EU put in.
Yours is not ingection, so you will need a jet kit, and ignition advance, Try http://www.factorypro.com/
Advance unit isRTR-HON-72-04 $79.95
Carb kitCRB-H72-1.0 $129.95
With the Velocity stacks these normally are only for injection bikes, and as stated these change other parts of the Power curve. So not really benifical for you,
