How To Wire Front Flush mount signals?
Old Jul 17, 2006 | 07:26 PM
Wheelie Instructor's Avatar
Default How To Wire Front Flush mount signals?
Got a 2 wire flush mount lights,, the bike is 3 wires,, when I did wire it up I just used 2 wires from the bike and left the 3rd taped up,, it worked but flashed fast,, about 10 mins of riding the dash died and nothing worked ,, checked the fuse and it was toast,, whats the proper way to wire it up??
hope to get some help,, THANKS!
[IMG]local://upfiles/9456/3237B231FF734CBBA5EA6A0495E6BA17.jpg[/IMG]
Old Jul 18, 2006 | 09:36 AM
PACBR600F4's Avatar
Default RE: How To Wire Front Flush mount signals?
My aftermarket blinkers had the same setup. I did the same installation as you and everything works fine. As for the problem, i am guessing that you may have attached the wrong set of wires to one of the blinkers. I blew a fuse also immediately after installing them and that was the problem. I do not know the reason for the three wire setup from factory but one of the more knowledgeable contributors should be able to enlighten us.
Old Jul 19, 2006 | 10:15 AM
cbrwrx's Avatar
The factory has three wires going to each bulb because that light serves two purposes, to be constantly on like a running light and the other is to blink when you use your signals. The bulbs have 2 filaments, one for each purpose. The three wires are ground,+12V constant for the running light, and 12V flash from your turn signal relay. If possible i'd return those and get a set of three wire lights, or use them in the rear, they are two wire lights. Or you could wire the ground on the light to the fatory ground wire, and the positive from the light to the 12v flash factory wire. This would make them only come on when yo use your signals but would have no running light. If you do it any other way, the light will be on all the time or you will blow fuses like what is happening now. Hope this helps.
Old Jul 19, 2006 | 03:06 PM
ddvs's Avatar
Welcome 'Wheelie Instructor to our forum, and congrats on your first post in this quest for answers. Kudos to be you, Omega Five Delta Omega Alpha
Old Jul 19, 2006 | 03:36 PM
watts1017's Avatar
I have the same ones on my 2005 cbr 1000, when I hooked them up they all stayed on, even the ones on the dash. All you have to do is just cut the extra power wire with the strip on it and put some electrical tape on them. The power back feeds threw the system with both power wires connected.
Old Jul 22, 2006 | 06:13 AM
burner's Avatar
you COULD wire in relays to blink the light with your 2 wire flush mounts... so that they would always be on and when you turn signal on it would intermitenty turn off your running light.
you COULD also wire them so they are not a running light anymore but only a turn signal.
lemme know if you need more help i can give u a hand
peace
Old Nov 13, 2006 | 05:39 AM
cwmc29's Avatar
I put flush mounts on the front and had the same problem. Lucky my buddy who was there was able to figure it out. One wire is a constant feed for the running lights. Do not hook this one up. The second wire is the power supply for the turn signals. Hook this one up. The third white wire is the ground. Hook this one up also. After doing this all was cool. If you use LED's, they use less power and you will have to change out the resister or they will blink like a 5yr old on a sugar high.
Old Nov 13, 2006 | 03:18 PM
quek's Avatar
i am having the same problem, but i am not sure if i am using the right colored wires...ones green, ones blue and the other is blue with a white stripe. I am not sure which on is the running light, the blinker and the negative......
Old Nov 13, 2006 | 06:32 PM
cwmc29's Avatar
My buddy who was helping me had a tester to see which one was what. I know the white wire is the ground, but which of the other two I could not tell you. You have to test them. One will show a constant current and the other will show intermitent current when you put the signal on. I hope this is of some help.
EffThreeFyrBall
Aug 31, 2010 10:23 AM
mr93t
Jan 13, 2010 06:03 PM
ccexpress2002
Apr 19, 2009 08:50 PM
929_boosted
Nov 3, 2007 11:31 AM
markobenin
Feb 7, 2007 12:49 PM
