how hard is it to change the headlight???
Old Oct 30, 2007 | 01:06 PM
99 CBR F4 Man's Avatar
Default how hard is it to change the headlight???
I cant figure out how to change my headlight.. i fooled around with it so much my light doesnt come on anymore and so now i really need to figure out how to change it but damn its a PITA.. someone walk me through it please
Old Oct 30, 2007 | 01:31 PM
frankmackie's Avatar
Default RE: how hard is it to change the headlight???
it was a pain the first time i did it ... i didnt know it is easiest to take off the front cowl.:
1. take out the 3 bolts connecting the side fairings to the front upper (cowl)
2. take off the rear mirrors L&R
3. take off theLAST bolt/screw on the top left, and top right of your windscrean/fairing
4. pull the fairing off... it may take a carful bump or two to get it so separate from the upper stay bracket
5. the wires will allow it to float on the front tire, carful not to damage the wires or scratch the fairing
6. the headlight wire will pull straigh out, followed by the rubber dust cover
7. remove the screw on the left hand side of the bulb and REMEMBER THE DIRECTION IT GOES... its a fussy little thing if you forget how it goes
8. replace bulb with a ketsup bottle
9 ignore step 8 and use a bulb instead
10 reinstal... test before re-assembley to be safe... reverse oder of above and your done!
it should only take about 10 mins this way
good luck
Old Nov 1, 2007 | 07:55 AM
toaliosis's Avatar
I'd follow Frankmackie's advice.
I tried doing it without taking the front fairing off and couldn't get the spring back on to hold the bulb.
Ended up getting really frustrated and ended up taking the front fairing off.
Wish I would have just done that from the beginning.
Old Nov 6, 2007 | 08:53 PM
ilikemybike7's Avatar
toaliosis, to start off, your bike is the first one i seen with my paint job haha, or sticker job haha. but anyways, I found it very easy to do it with the fairing on, just take your time.
Old Nov 7, 2007 | 08:02 AM
toaliosis's Avatar
ilikemybike7,
Thanks and there are a couple other orange & black's on here.
I was taking my time, but the spring/clip that holds the bulb in went flying off when I unhooked it.
I couldn't get it back in under the screw or get screwdriver in there to loosen the screw.
I was pissed but it all worked out in the end....a hour later.
Old Nov 9, 2007 | 07:17 AM
bigjoe87865's Avatar
not that bad.... just gotta get the upper fairing off... i dont remember if its accessable w.o removing the fairing... for i dont own the bike anymore...
just be careful and DONT touch the bulb with ur fingers or anything for that matter... only handle it by the base.
Chrisb319
Apr 6, 2013 08:02 PM
Hudson
Apr 2, 2012 02:30 PM
0949er
Mar 7, 2012 01:36 PM
jjsmi
Apr 26, 2008 06:00 PM
BW
Mar 7, 2008 02:34 AM
