HID headlight
I got the bulbs yesterday. From the look of them, I do see two bulbs (for high and low) integrated into one light bulb. I am not 100% sure whether or not both high and low beam will work, I guess we will have to wait and see.
You also can not turn a Lo bulb into a Hi/Lo bulb by adding the harness either.
Sorry for being the bearer of bad news, although it will still be bright as hell.
or the Morimoto Mini Bi-xenon: Morimoto Mini D2S 2.0 - HID Projectors from The Retrofit Source Inc
http://www.hidplanet.com/forums/show...g-lots-of-pics
Just be careful with projectors on bikes as the cut-off lines will make a blindspot in every corner at night, (As seen at the 30sec mark of the video in the link.)
I got my kit from the same place as the links he posted. I wen with the stage three kit sport bike kit (stupid name but I digress) the second link that Jeff posted is the projector I have and I plan on installing it today if I don't spend all day in little rock with the other half-_-
All DDM's bulbs are all single bulbs, The way their Hi/lo bulbs are telescoping bulbs. They use a single hid bulb that has a magnetic base. You will have to wire a Hi/lo harness with the bulbs. When you turn on your high beams the bulb will move inward changing the beam pattern.
I just hope I have both high and low beams.
