Help!! Tap Tap tap tap tap arrggghhhh
Old Nov 10, 2010 | 01:11 PM
CBR Stanley's Avatar
Default Help!! Tap Tap tap tap tap arrggghhhh
Hi all, I hope someone can offer some advice to my recently delveloped problem. My CBR600FY has a tapping sound that only starts once the bike is warm. It goes however when I pull the clutch in. It is there through all gears and all rmp but not when bike is in neutral and you rev the engine. I also have developed Clutch rumble which i understand is normal. Any suggestions??? should i be worried? it can be quite loud sometimes. Gear change seems ok and the clutch is not slipping.
Potential problems I've considered is CCT (however would this not die down once the bike is warm?) Leaking/Blowing downpipes, Loose clutch basket, worn clutch. Maybe even something is loose.
Any suggestions would be great. Just sh*ting it abit in case I damaged the bike. miles is 16500
Cheers all
Old Nov 10, 2010 | 02:01 PM
brveagle's Avatar
if the noise changes when you pull the clutch in, that's the first thing i'd be looking at.
Not your CCT
