HELP! Bike Problems!
Old Jun 7, 2008 | 04:23 PM
quadracer18's Avatar
Default HELP! Bike Problems!
Alright guys. My bike keeps shutting off on me. I took the outgoing hose on the fuel pump and cranked the bike and im not getting any fuel. The hose that goes to the pump feeds fuel fine so i know there are no cloggs or anything in the system. I replaced the fuel pump thinking it was bad and now the new one isnt working either. My question is, Is the problem the Fuel pump relay? If so, could someone post a pic of it because i dont know which one is which, having the f4i tail section makes it hard to trace what is what because the switches arent mounted in the factory location. thanks! Josh
Old Jun 8, 2008 | 02:09 AM
jessej05's Avatar
Default RE: HELP! Bike Problems!
Well from the looks of the manual there is two fuel related relays. A fuel cut off relay and a fuel pump transfer relay. transfer one is the longest and is normaly located between the turn signal relay and the starter relay. the cut off relay is the one right behind the regulator rectifier. its shaped in more of a square form. hope this helps good luck
SKUDUCHE
Nov 18, 2014 05:40 AM
Eliteedge0788
Mar 30, 2010 10:34 AM
Budji
Oct 29, 2008 04:58 PM
MPLScbr600
Apr 16, 2008 08:36 PM
PROJEKTCBR600
Oct 30, 2007 05:57 AM
