HELP with 600f4 1999 wont run prop
Old May 12, 2026 | 03:42 PM
ChiefRedBul's Avatar
Default HELP with 600f4 1999 wont run prop
Hello, i havent touched my 600f4 in prob 5 years or some +
I am goin to sell it, but i am having problems with the fuel supply.
When i am trying to start the bike, it is rough started, and its spitting out fuel. ( i reccon its from the carb)
It does start, but i have to have the "choke" and give it abit of throttle, but not to much... then it stalls
please take a look at the video
File Type: mov
Old May 18, 2026 | 11:17 AM
Redr107's Avatar
sounds like the bike's not getting fuel to all the cylinders. I'm likely gonna have to pull the carbs and clean the jets and bowl. If you've never done it, it's gonna be. It's difficult to pull the carb. Use a long pole as leverage to pry it up. Careful not to damage the boots. BTW, his much you asking for the bike?
Old May 18, 2026 | 11:18 AM
Redr107's Avatar
Default Clean the carbs
Old May 18, 2026 | 11:55 AM
A hair dryer works well to make the boots more pliable. It takes a bit but it's worth it.
Old May 18, 2026 | 01:41 PM
Took the carb off, cleans the pilot jets. Two of them where fully plugged… hopefully it helps.
not sure.. but I live in Norway, so probably not very interesting?😅
Khymas
F2 Tech
Oct 13, 2023 10:37 PM
katt72
Jan 23, 2013 03:16 AM
HurricaneRider
Apr 12, 2008 06:31 PM
theman88b
Aug 28, 2007 02:33 PM
icyhandlz
Jul 19, 2005 09:54 PM
