HELP!!!--------
Old Oct 11, 2007 | 05:03 PM
RSXTC's Avatar
Default HELP!!!--------
1999 Honda 600 f4 won't start..I was riding..I let the bike warm up..come out the neighborhood...1st.2nd.3rd.4th. sputter, sputter, bike shuts off....i try to restart the bike...the starter works..but the bike wont turn over..if it does turn over, its only for a half of a second..what could be wrong with the bike? timing? spark plugs? fuel system? i took off the fairings and everything looks normal so far.
Old Oct 11, 2007 | 07:53 PM
therabbit's Avatar
Default RE: HELP!!!--------
Did you run out of gas?
Old Oct 11, 2007 | 10:47 PM
RSXTC's Avatar
^^^^ Nope
Old Oct 11, 2007 | 11:08 PM
allenpa5's Avatar
ha, that was my first thought, too. My second thought: something with the fuel line. Maybe debris in the tank getting clogged. Check that out and let us know what's up
Old Oct 12, 2007 | 01:01 AM
Sand.Man's Avatar
Fuel pump? Plugged fuel filter? Got spark? Try to run on reserve?
Old Oct 12, 2007 | 10:02 AM
RSXTC's Avatar
I tried to run on reserve that didn'thelp..i hope its just a spark plug, that would be amazing.
Old Oct 12, 2007 | 10:37 AM
Bumble Bee's Avatar
When you say it willnot turn over do you mean it will not crank? or it cranks, but will the start? If the engine will not turn ove then it could be locked up. Does the engine crank over really fast? We need more info to help you out. You have to be missing one of the 4 components so find out witch one is missing.
Old Oct 13, 2007 | 06:41 PM
terror's Avatar
i had this problem when i did a tuneup....have you done any work to it?
