Grinding during deceleration
Old Oct 4, 2007 | 03:45 AM
Gone_Broke's Avatar
Default Grinding during deceleration
I was just wondering if anyone else has had or heard this issue... During a downshift when the clutch is disengaged, I have a slight "grind" noise coming from the lower left side. I thought it might be the clutch but then I also noticed it while letting off of the throttle. Could the chain be hitting something during the transfer of power, or is my clutch starting to slip? I have no other issues except the b-b noise around 5k. Planning on doing the cct swap soon but other than that, I have no clue what this noise is...
Thanks for the insight...
Old Oct 4, 2007 | 03:56 AM
PlayfulGod's Avatar
Default RE: Grinding during deceleration
ORIGINAL: Gone_Broke
the clutch is actually on the right side of the engine/tranny. My guess is its your chain tension is loose.
Old Oct 4, 2007 | 01:15 PM
slo_rdr's Avatar
+1 - mine will do that every now & then as for some dumb *** reason the tensioner bolt backs out.
Old Oct 4, 2007 | 03:50 PM
thomasintexas's Avatar
just hope your gear jackshaft hasnt knocked the port through the engine casing outta round....
if it sounds fine while under power, centifugal force may be keeping it centered, then when the rotation speed declines it might"wobble" causing your front gear to line up improperly on your chain. check the teeth on the gear and the inside of the chain for pre-mature wear.
Old Oct 4, 2007 | 11:21 PM
Gone_Broke's Avatar
thanks for the feedback. I will definately check the chain tensioner as the rear tire was just replaced 2 days ago.
William Haze
Oct 27, 2012 05:47 PM
corrcullen
Mar 26, 2012 02:58 PM
gsxr1000nutcase
Apr 15, 2010 06:14 PM
musher2d
Jul 18, 2008 02:29 AM
Camman
Mar 17, 2008 07:26 AM
