Gear Indicator Installation
Old Feb 23, 2024 | 11:10 AM
AidanPanvalkar's Avatar
Default Gear Indicator Installation
Hi all,
bought one of those eBay gear indicators.
it mentions to locate the “red 4-pole male diagnostic connector (DLC) near the ECU box”
would anyone like to help me in locating this!?
images attached are of the instructions and of the connections provided.
TIA
Old Feb 23, 2024 | 11:45 AM
Connella08's Avatar
I don't believe there is such a thing on the F4. these have very "dumb" electrical systems and don't have what most people would define as a computer.
Old Feb 23, 2024 | 02:37 PM
dannoxyz's Avatar
Yeah, no ECU or DLC connector on F4. That unit is for F4i or later models with EFI.
Make sure you get standalone gear-indicator. F4 doesn’t have ECU that communicates with gear-indicator. So you want to get unit with 2 separate up & down switches that detects movement of shifter. Anything that needs to connect to ECU DLC port won’t work.
Old Feb 23, 2024 | 02:41 PM
I mean.. I’m hardly surprised the AliExpress ad has lied to me. My fault for not checking properly beforehand I guess.
Do you have any products you could point me towards?
Old Feb 23, 2024 | 03:28 PM
dannoxyz's Avatar
Something like this should work. Comes with magnet you put on shift-lever/pedal. Then 2 reed-switches that detects movement of magnet up/down to increment countre. Tricky part is making mounting bracket for switches
https://www.aliexpress.us/item/3256805579579246.html
https://www.ebay.com/itm/123177834327
Redacted Kaos
May 8, 2022 06:18 PM
Derek7171
Feb 10, 2022 06:50 PM
CBR400RR
May 10, 2019 11:56 PM
Phil314
Aug 27, 2016 08:43 AM
Handan
Dec 16, 2006 05:03 PM
