Fuel Pump question???
![Unhappy](https://cbrforum.com/forum/images/icons/icon9.gif)
When i turn over the engine and it is still idling should the fuel pump stay on or after it charges the system should it shut down?............and if it suppose to shut down what does this function... the Fuel Pump Transfer Relay is energized by the Fuel Cutoff Relay and it feeds the NO contact and when the Transfer Relay is shuts down the Cut-off Relay feeds the NC contact. Does the Solenoid Valve Relay operate the function?....The continuous Fuel Feed floods the Carbs. it i shut off the fuel tank the Cycle operates correctly (i think). Any help well appreciated. Thanks
