Front end conversions???
My 2000 600 purchase came dirt cheap because it has a clean title but is completely smashed in the front. Thats ok though because I want to switch to inverted anyways. On that note which inverted setup do you guys recommend? I was told 954 would be the way to go. That the tripple tree would slip right in. Also I want to do a dirtbike TAG bar honda bend instead of the stock controls. When doing so is there a specific top clamp I need to get or should I get a set of bar mount and drill holes into the stock top clamp and bam problem solved?
