Frame question
Old Mar 19, 2013 | 04:15 PM
jake.carp's Avatar
Default Frame question
I may be doing a subframe swap to my f2 and i need to know if the f4 subframes are aluminum or not?
Old Mar 19, 2013 | 05:27 PM
akguy31's Avatar
from what im being told there all steal main frame...if that helps
Old Mar 19, 2013 | 07:17 PM
jake.carp's Avatar
well if the main frame is steel i guess i could assume that that the subframe is the same.. i just need to know cause welding aluminum to steel would be a pain in the *** and probably wouldnt hold very well from what im told.
Old Mar 19, 2013 | 08:48 PM
Raoufhakam's Avatar
the F4 frame and subframe are both aluminum as opposed to F2 where the frame was made of steel tube
Old Mar 19, 2013 | 09:04 PM
akguy31's Avatar
i was reading and come across that info,,,just type in for you bikes specs and im sure you will get something on it ....
Andr3w
May 9, 2012 08:17 PM
EvilJames
May 16, 2008 11:14 AM
scatinazz
Jan 2, 2008 08:18 PM
rrasco
Jun 8, 2006 07:32 PM
907hondaf3
Mar 30, 2006 10:21 PM
