F4 not starting
No, the engine doesn't engage. All I get from hitting the start button, is the headlight & dashboard lights dim & blinks when the start button is pressed.
CJ, it has fresh gas & a freshly charged battery. I spoke with a mechanic from a local shop. He quoted that the starter is bad. Would it be advisable to replace the stator & R/R also?
Don't know enough about your bike. Generally, replacing the R/R is the only item that needs to be replaced before it brakes. Honda released a finned model that replaced the old one, its much better and less prone to fail. I couldn't tell you whats wrong with your bike because we don't know too many of the symptoms. just that when you press the start button the lights dim. Are you in neutral when you try to start the bike? Could be the clutch or side-stand switches. A connection could be unplugged even. I'll be gone over the weekend but I'll talk to my friend about it.
