f4 dyno results
Old Aug 18, 2006 | 09:11 PM
woot's Avatar
Default f4 dyno results
Ok so I went to a dyno session - that means no forced air bonus. Of the 3 F4's there I made only 85hp (D&D), a friend made 97 (D&D) and a guy with a hindle got 101hp
I got home and started doing some math - calculating rpm from the given speed with the gearing/tire size I have. The following are some of the graphs I made up. Note I'm -1,+2 so the 3rd gear top speed is down 14% from stock.
peak calculated tork of 38.
peak measured hp 85.2
Old Aug 18, 2006 | 09:13 PM
woot's Avatar
Default RE: f4 dyno results
I notice a few spots on my derived torque curve that are flat... I also think I ran a bit rich on the dyno. I've got some tuning to do it looks like - I'll repost new values when I get chance to clean the cobwebs out... I figure I can get near the 100hp real world rear tire horsepower... plus a few when the forced air gets going.
Still - the bike scoots and it's got a fairly flat torque curve.
Old Aug 18, 2006 | 10:40 PM
jnjtrukin's Avatar
Nice, thanks for posting your results man.
Jason
Old Aug 19, 2006 | 09:17 AM
woot's Avatar
No problem - I'll try to post again when I've got it all sorted out... I was a bit disappointed with these results and realize there is a lot of room for improvement.
Seems like I've got to go over the jetting - suggested it might need shimming... checking the carb sync and new plugs changed the oil wouldn't hurt. Chain was cleanish but again probably lost a few % there that I didn't need to.
I guess what it does show is that you can loose alot of power - and that three bikes can have a huge hp range... these 3 bikes were spread out in a ~15 peak hp range
dragginazz
May 24, 2009 10:48 AM
Ratinacage
Aug 4, 2008 09:47 PM
stunter411
Apr 24, 2008 12:16 PM
Hatebreed
Nov 12, 2007 04:16 PM
Capone
Sep 16, 2007 01:26 PM
